1 - 5 of 5 Posts
Here are the preliminary dyno sheets for my custom mapping....
The tech is having problems with the edie brake and it is not holding loads, so they are not charging me for this mapping....when they get the new dyno parts I should be back in there getting it smoothed out some more.
The blue is with the Dan Kyle Sato Slip-On map....
Cleaned up the air/fuel ratio quite a bit....not much gain on the HP and Torque...but the gain is all the way thru the power band.
man that a/f is all over the place isn't it?? even with the partial mapping.
The dan kyle map is the blue line....yes, it's all over the place.
WOW, so i must have more HP than you DB? :thumbsup: J/K, keep us updated on your offical numbers, if i come back through with the bike i'll give you another run!!
is this a new dyno for them? Have they set the PID numbers correctly for the brake ? I'm guessing THIS is there prob, but if they are having a "part" sent out, then maybe not.
1 - 5 of 5 Posts
