1 - 3 of 3 Posts
CRG Hindsight bar-end mirrors are ideal for anyone that wants to clean up the look of his bike yet still retain the ability to see backwards without having to turn around. The 3–½” diameter mirrors are slightly convex to magnify the reflected image. This makes it possible to easily discern objects behind you. The glass is also slightly tinted to reduce glare on bright days. The bar end mirror clamps on to the end of any standard 7/8” bar (common on modern, non-cruiser bikes) and can easily be positioned for optimal rearward viewing. The entire chassis, from clamp to mirror frame, is constructed from 6061-T6 aluminum that is precision machined for an exacting fit and good looks. Every component is held together with stainless steel hardware and the mirror itself is isolated from vibration with a rubber damping mechanism in its mounting stalk.
Sold individually, you can get these mirrors in a black or silver finish. Every component is reversible, so you can mount these on either the left or right bar of your motorcycle; or you can buy a pair and have both sides covered!
These are not yet available on our website, call TJ at 866.931.6644 ext 817 to get yours today. You can also email us with your questions: send those to FORUM at RIDERSDISCOUNT dot COM with CRG HINDSIGHT in the subject line.
What’s in the box.
As with everything CRG, the machining quality and finish is of the highest class.
Should the unfortunate happen and you damage your CRG mirror in a crash, replacement parts are available thanks to the Hindsight’s modular construction.
Joint system allows you to easily position the mirror exactly where you need it. It’ll stay put too.
can you get me a quote shipped to 73628
1 - 3 of 3 Posts
