Classic good looks in an all-American made design, the Hindsight Mirror from CRG add exceptional styling to your motorcycle in an easy-to-install design.
Each mirror is fabricated using a combination of anodized aluminum allow parts, stainless steel hardware and a 3” diameter convex glass rearview mirror. It’s all assembled in an elegant package that looks good on any bike. All you need is 10mm of space on the end of your 7/8” handlebar to make room for the aluminum clamp. No other special hardware is required.
Once installed, simply adjust the mirror so it’s in the right position for your viewing needs and hit the road. You’ll find the convex mirror provides just enough magnification, despite its lithe size.
Hindsight mirrors are sold individually, so you can go with a single-sided or dual configuration – the choice is yours. Each kit comes with a clamp for 7/8” handlebars, and for custom bike builders, adapters can be had for fitting the mirror on 1” handlebars as well.
To choose your mirror from a range of colors: black, silver, red, gold or blue, call TJ on 866.931.6644 ext 817 or email [email protected] with CRG HINDSIGHT MIRRORS in the subject line and we’ll get back to you right away!
