1 - 4 of 4 Posts
I got 04 ZX-10 motor with a spun #2 rod bearing. I got crank and another set of rods that im going to replace the damaged stuff with; however, I'm having trouble finding the right sized plasticgage for the specified crank/rod clearance sizes. Why is this, or am I doing or reading something wrong? I have the following plastigage sizes: Blue(.102-.229mm), the Red(.051-.152mm), and Green(.025-.076mm). The specified bearing crank clearances are from (1.491mm-1.503mm). Has anyone else gone through this before? :dontknow:
your rod bearing clearance should be between .030-.060mm with a service limit of .10mm
your main bearing clearance should be .010-.034 with a service limit of .060mm
Premium Member
What you are calling the "clearance" appears to be the total thickness of the insert. What you are looking for is the clearance with the insert installed.
P.S. I'd strongly suggest going by the markings on the crank and cases to pick the bearing inserts, and using the plastigage only to check that you didn't make a major foul-up.
Wow, man I didnt go far enough in my manual. I appreciate it guys, just had a case of the dumb-ass.
1 - 4 of 4 Posts
