1 - 2 of 2 Posts
My bearings have numbers like D8D3 and 818A on them. These numbers dont cross to OEM part numbers. Same with rod bearing numbers D1L3? I know they are supposed to be color coded but no colors are visible. Is there a way to cross these numbers??
I want to order the same bearings to see how far off they are then order the right bearings if the clearance are out of range.
With the proper precision tool you can measure the thickness of the bearing in question and cross reference the color/part number in the service manual. You can also check the case stamp/markings for what they should be, provided this is the first time the motor has been apart.
1 - 2 of 2 Posts
