Had to use an impact gun on my front sprocket nut to get that sucker loose (also gave it a few good wacks) when replacing chain and sprockets. Now there is a really bad whining noise under acceleration coming from the front sprocket area.. almost sounds like a trumpet and increases in pitch with speed (not rpm’s). Any chance the impact gun caused the countershaft bearing to go bad? Bike was in neutral and I used a screw trough the old chain to hold the sprocket while using the impact on the nut.
The countershaft feels fine when I rotate it with the sprocket off. No play or binding/ grinding.
Chain tension are within specification and wheel is aligned. New 525 chain matching with sprockets
