1 - 20 of 23 Posts
I have just bought an Akropovic Evo full race system for my bike (ZX10R 06)
I have a couple of questions for anyone in the know
Emmision sensors (mid pipe/before the cat)
How do i remove these, is it simply a case of unscrewing them and removing them and unplugging the sensors from the loom? if so, will this give me any fault lights?
Exhaust Servo
Located under the seat. Opperates on cables to the section just after the cat. Can i just remove all this stuff and again have no FE lights or anything come on?
Feedback appreciated
__________________
Rent this space
You need to disconnect the cables from the servo and leave it plugged in, and if you have an O2 sensor , you will need to buy the eliminator kit for it, or weld an O2 bung in the new exhaust and use the sensor ,if it doesnt come with one already in the pipe.
With all due respect, i aint welding nuffin onto a full race Akropovic system :)
But, your other points make sense and thank you, remove everything but the servo...............
**Edit**
Sorry misread your post........I dont "think" there is anywhere for the 02 sensors to go on the full race acro system (dont get it till Saturday) hence can i just take them off and not suffer with any error lights comng on the dash?
La Flama Blanca
Not sure about 06, but my 04 Evo System has the bung already there.
Make sure you do not touch the sensors when you have them out, the oil from your skin can ruin the sensor.
Well I had the full race akra and it does come with a thread hole in each pipe for you to screw in the O2 sensors. I be surprised if it comes without. If so just buy 2 dynojet eliminators and plug it right into your harness. you will need these if you plan on racing and is finicky about your fuel map, as the original sensors will tend to lean it out, but only within a certain rpm range. Exhaust servo as mentioned above.
Cheers, :)
Just have to wait for Saturday i guess :) Not long.............Its Christmas come early for me :lol:
Left to go.........
PC3
BMC airfilter
Ohlins rear shock
Front fork work
Dyno'ed
4 day Track Day at Catalunya in April to try it all out
Cheers, :)
Left to go.........
PC3
BMC airfilter
Ohlins rear shock
Front fork work
Dyno'ed
Euhm, shouldn't you get this done together with the full system?? Your airflow, fuel mixture, motor management will be all f*cked up if you put in the full system without PCIII, airfilter and dyno the bike with custom mapping!!
Good luck in Catalunya!:wink:
Cheers, :)
Left to go.........
PC3
BMC airfilter
Ohlins rear shock
Front fork work
Dyno'ed
Damn you have to wait till April to try out the bike with all your mods on it.:headshake Thats a helluva long time to wait.
Discussion Starter #10
Yep, but the bike aint going anywhere till april :sad: ..............plenty of time :cool:
Discussion Starter #12
Tell me about it, i may get another track day in this year :dontknow: its always cold and wet in the UK :rolleyes: whilst i dont mind riding in the wet (with wets in etc) i would rather test it in the dry :) Hence Spain in April :)
Bring it on !!! :cool:
Maybe you can help me out here, bro? I live in Belgium, and I love the UK, I'd love to some trackdays in the UK!
All I know is this: http://www.hottrax.co.uk/. Do you know this? Is this any good and do you know of any other ways to book some trackdays in the U.K.??
Anything South of Birmingham is OK for me! If you are doing any days I could also register for one and we could mee up and have a :eek:ccasion1 !! :mrgreen: :wink:
Discussion Starter #14
Hottrax are good, also check out focussed events and track sense.
Hmm south of birmingham eh? Silverstone and Brands Hatch spring to mind, Have a look here
http://www.focusedevents.com/
http://www.tracksense.co.uk/ **Edit having looked, these are europeon track days**
There are some cracking circuits north of Birmingham as well :) Cadwell, Croft, Oulton Park (i live 2 mins away from Oulton) which is handy :) loads of them, Anglesey has just had a massive investment and even has a mini cork Screw, Laguna Seca style :)
HTH
PS, im always up for a beer ;)
HTH
"Focusedevent" looks promising!! I'll add that one to my bookmarks and check it out!
South of birmingham is because of distance/time. I live about 1 hour from Calais in France, which is perfect to take the boat there to the U.K. , I'm in or around London in about 4 hours from my house, so that is good. Once you go past Birmingham, Manchester, Liverpool, and further the time/distance is just to far for a trackday. But Brands Hatch and especially Silverstone will do me just fine!!
You'll need two 02 eliminators from Dynojet, make sure you order for the right year, the 06 and 07 have different connectors. There's two connectors just below the coolant expansion tank, a bit fiddly to remove but it's not a job you need to do regularly.
Discussion Starter #17
Yep Cheers Doug, bike all stripped down, so i can see em :)
Discussion Starter #19 (Edited)
OK, hang on
**runs out to garage to take a pic of the bike ATM**
Its a sad looking sight at the mo, ill warn you................
Discussion Starter #20 (Edited)
Big files coming through and i have to send em from my work account, through to my home, then up load em..........Bloody PC wont recognise my SD card
Anyway, here is the first :)
Its all gone :)
From the side
And another
Pick the full system up tomorrow at midday, ill probably get cracking putting it on (GF allowing) so ill put some more pics up of the install :)
HTH
1 - 20 of 23 Posts
