Thank you so much sir!Torque - Water Hose Clamp Screws: 3.0 N·m (0.31 kgf·m,27 in·lb)
Definately will do. The clamp was loose not sloppy but it was easily turned with minimal effort.keep eye on that hose or area.
The loose bolt is probably the problem but, fyi, I had either r1 or fz1 that did the coolant two drop thing and if was a failed water pump gasket.Definately will do. The clamp was loose not sloppy but it was easily turned with minimal effort.
Sent from my XT1565 using Tapatalk
