1 - 6 of 6 Posts
Hello all,
It's been a while since I've posted, but I still lurk every other day or so. Hoping to get back on a 10 next year.
Anyways, I've been helping my buddy with his recently and he purchased a convertable clutch from Hays. It's a piece of artwork for sure. I am using a clutch kit from Cycle Concepts, which my buddy had in his bike before (survived 2 years of hard launches), but this one looks different than the other one I put in for him which may be the issue. Old Cycle Concepts clutch kit was all fibers and steels. New kit comes with a double steel something that looks like a cushion spring or something of the like. The rest of the steels are dimpled unlike the old clutch kit I put in where the steels were solid.
I got everything installed from the new clutch kit, missing a friction and steel to get proper stack height and the bike is having issues. It's like I cannot get enough clutch travel. I adjust the cable to completely engage the clutch and I cannot disengage fully. I adjust to disengage fully and it will not engage all the way. Tim Hays sent the clutch ready for street mode. It has 3 springs triangulated on the cover with 4 springs between the cover and the hat. No springs on the outside for it to be a slider.
I played with stack height using the old steels without the new cushion double steel thing, had air gap everywhere between .058-.104 and the problems with the clutch not moving enough persisted. No combination I could do solved the issue.
I've been talking with Tim Hays and he really doesn't know what's going on. Any help or advice here?
Thank you
Hello all,
Thank you
Is this a Hay's lockup clutch
If I read you first post right your putting in a clutch thats 2 years old. Not the best Idea. I'm sure you checked for warped plates and their all good. Whats the recommended stack height. You may have to screw around with a couple of different combinations to get it right unless your sure you have it correct. I had an MRE lockup clutch in my SC dragbike. I had to add an extra fiber to get the stack height correct. Your better off trying to adjust stack height with fibers than steels.
I have a brand new clutch pack with steels that I first tried to install. I was using the 2 year old steels to swap out the new to attempt to get the stack height correct. Where did you add the fiber? Did you have it fiber to fiber?
I added the fiber at the top of the stack so it was fiber to fiber.
1 - 6 of 6 Posts
