I would avoid the "MaxSpeed" rods unless you plan on changing the bolts and having them re-sized after you do. When you price that, they usually end up being more expensive than Crower/Carrillo.
As far as those two brands go, I have had both in my hand at some point for a Gen 2, and my next set will be Crower's. Surprisingly, they are usually a bit less expensive, but they are a much more robust rod. They weigh a few % more each over the Carrillo's, but you also get bushed little end compared to the hard chromed end on the Carrillo... On the two sets I had I also found the clearances to be a little better on the Crower's, especially on the little end.
Regardless of which brand you choose, get the best rod bolts you can afford.... In my experience rod bolts are over 99% of non-oiling or sizing related failures.
