1 - 3 of 3 Posts
06 ZX10R
Looking for some advice. Just did compression test all cylinders read same about 125. Bike is cold, hasn’t been started in about 2 weeks and it’s only 37 degrees outside. I’m in garage though. Why is it reading so low? Should I pull valve cover off and check for broken retainers, etc.? I wasn’t having any issues when I parked bike. Just doing winter maintenance and need advice if I should just throw new plugs and coil packs and go on or look to see about having cams and everything looked at? Thanks.
Automotive tire Motor vehicle Automotive design Gauge Engineering
Tire Wheel Fuel tank Automotive fuel system Vehicle
Motor vehicle Speedometer Gauge Measuring instrument Vehicle
Tire Vehicle Wheel Automotive tire Automotive design
Product Sleeve Sportswear Personal protective equipment Font
Throttle blades being wide open helps. A warm motor will also help/read higher. Your static elevation will have a pretty dramatic effect as well... high elevations will show lower compression numbers.
1 - 3 of 3 Posts
