On my third Gen4 (the previous two lasted ~100,000 km before being taken out in accidents) and after 206,000+ km (128,000 miles) yep, one of the outlet valves snapped on #1 cylinder, snapped the spring retainer, bent another exhaust valve, bent an intake valve then embedded itself in the top of the piston, smashing into, splaying, and destroying the spark plug. Several parts of the failed valve went through into the headers (made a lovely rattling sound when I removed them!)
After much work, the engine is out of the bike and the crankcase split. I don't have the gear needed to check the trueness of the crank and the head will need machining (valve seats). So, what are my options?
Rest of the bike is in mint condition - gearbox replaced ~15,000 km ago, clutch replaced ~20,000 km ago, new radiator, new gas tank, new fuel pump, new stator, new head stem and wheel bearings, panels in pristine condition. I also have three sets of stock exhausts with two cats, three sets of OEM levers, two sets of OEM pegs, a spare front and rear with new bearings.
Sure, I've been looking at a brand new '21/'22 ZX-10R too. The MY22 model is awaiting homologation - should be available in late January.
Thanks for your advice,
Arc.
- Sell the bike for scrap
- Part out the bike (easy to do as it's already in many parts!)
- Replace with a second-hand engine - none so far found in Australia (or the world)
- Get the crank checked for trueness
- Replace crank bearings + big end bearings
- Replace 4 cylinders (?) + rings + replace 8 con rod bolts (designed to stretch)
- Get the head machined and
- Replace 16 valves
- Replace 16 valve guides
- Replace 16 sets of collets
- Replace 16 valve springs
- Replace 16 valve spring retainers
- Helicoil the spark plug thread
- Replace the entire head with a second-hand unit
- Sob quietly to myself
Arc.
