1 - 7 of 7 Posts
Speed Freak
can anyone tell me what the stock clutch spring pressure is for an 06? thanks
65 lbs....
barnett has springs 75lsb 85 lbs and 100lbs.... I'm actually running 3 100's and 3 stocks in my bike and it is holding pretty tight.... you can do a search i posted the 100's part number on here somewhere....
Just talked to Barrnet earlier this week, was told stock '08 springs are 62 psi. Im pretty sure they are the same as the '06. I ordered up some 82 psi's for $21, hell of a deal
Discussion Starter · #5 ·
thanks for the input guys. i have a set of 85s and a set 0f 100s. i was thinkin about doin three of each and no stockers at all. i am trying to find a way to get rid of any slip for right now untill i can afford a full lock up. we will see how bad it is with this set up.
Discussion Starter · #7 ·
well, i just put in three 100s and left three stock to see how it pulls. it seems still a bit light, but i may leave it in for now till i can ride the bike. if it slips the, i will change it out again
1 - 7 of 7 Posts
