1 - 4 of 4 Posts
If I have the adjustment for my clutch cable all the way out, is it time to replace the cable or do I have to change my clutch? I don't slip out of gears at all unless I am going from first gear to second and at high revs when I shift, it's like I go from first to nuetral... Any recommendations? Thanks
Licensed Dist of HaterAde
Have you tried setting the top adjustment all the way in and then adjusting or tightening it up at clutch cover.....on my 1st gen its where the oil goes.... :). If not then the cables are like $12 to $18 new.
:+1: and while you're at it, check the cable Ends for fraying. If they are frayed then it's time to replace it.
1 - 4 of 4 Posts
