1 - 20 of 20 Posts
I'm wanting to know once I get into 2nd if I just pop up thro the grears fast while WOT instead of backing off a tad and clutchin into the next gear if it will cause the front to pop up or get a little unstable. I will be straped and I don't have a DJ Quick Shifter or Air shifter yet so I just wanna see if its ok to bang the gears that way
It's OK to upshift without the clutch, but you'll have to "back off" a tad anyways to get it to pop into the next gear. The gear dogs are undercut to help keep them together under load. The only way to allow them to disengage properly is to preload the shift pedal, back off the throttle slightly, and bang it into gear. It won't hurt anything if done properly. If done sloppily it can damage tranny parts such as forks, shift drum, gear dogs, etc. The quickshifter interupts the ignition signal when a gear change is made to allow the tranny to unload in this same fashion for a split second while the throttle is still held open.
If you've never done it before, I'd recommend practicing it outside of a dragstrip environment first.
It shouldn't cause the front end to wobble or come up unexpectedly when doing this.
Look at the other thread you posted. I put up a vid of Norm Jackson and he is shifting without the clutch.
Thanks for the info. :)
The dogs are not undercut on the zx-10 tranny stock..........
The ignition will also not kill when you pull up on the shifter.
inappropriate
It's OK to upshift without the clutch, but you'll have to "back off" a tad anyways to get it to pop into the next gear. QUOTE]
You can hold WOT & slightly fan the clutch.........it wont let the revs drop that way.
I just got a damper. nice addition.
seems to be a topic that needs more researching
My dynojet quickshifter likes a positive/deliberate shift. I have gotten it between gears a few times.......... all were done halfhazardly........rider error I would say.
never had an air shifter so i dont know how they compare, but I do like the DJ.
Discussion Starter #14
see sig
inappropriate
clutchless upshifts are fairly easy to get the hang of. DJ shifter is the way to go.Just keep throttle pinned to the stop and upshift gear when ready.
I usually just keep the throttle pinned and snap the clutch. I guess everyone does stuff differently...
Discussion Starter #19
Discussion Starter #20
1 - 20 of 20 Posts
