1 - 7 of 7 Posts
Hey guys,
Time to replace my clutch plates and springs, oem is expensive... any recommendation?
Discussion Starter #2
Hey guys,
Oh yea, 2016 zx10r, I don't drag race but I do spirited riding, occasional hard launches, wheelies and such.
OEM. Aftermarkets are less reliable. It's expensive for a reason. Less expensive is also for a reason. On a stock bike, stick to stock clutch.
Kg clutch kit is affordable and works well for every bike I've used them in
Thanks guys
I tend to go for OEM clutch plates (steel) and EBC friction plates/springs. Reason for OEM clutch plates is that there a certain diameters that you have makes up the clutch kit as a whole.
Check your service manual I've included 2 pictures one for correct diameter as an example. Yet the other is for the correct procedure to set up the clutch lever I used ID card as the measure 1m Screenshot_20191107-234938_1573170731798.jpg
1 - 7 of 7 Posts
