What thickness are your steel end plates? Two steel plates next to each other in the middle of the pack is a bad idea...well it got it to 53.61 exact but i had to put 2 steels together in the middle of the pack
:+1:...you can buy thicker steels to compensate for height but DO NOT CHANGE the order :headshakeWhat thickness are your steel end plates? Two steel plates next to each other in the middle of the pack is a bad idea...
