1 - 6 of 6 Posts
Yankee Racer
you can get thicker plates. I think they come in three sizes. 2.3mm 2.6mm and maybe 2.9??? Stock is 2.6mm as mentioned in another thread
I use a 04 gsxr 1000 clutch stack in my 10.I had to add 1 more fiber and steel plate to get more height and added some round .030" thick shims under the springs to get more pressure..works great for me!
I've found that on a stock wheelbase 10R that 53.3-53.6mm works best for drag racing. You can adjust stack height with the different thickness steels.
this for 04 05 models only. the 06 07 need a bit different.
1 - 6 of 6 Posts
