1 - 7 of 7 Posts
Clutch noises?
Let me edit this to get to the point:
does your clutch make any sort of a noise? when you pull the clutch lever? is there a noise that sounds like bells jingling?
Gen2 Ripper
Pull the clutch cover and see if there are marks from it rubbing. If not, make sure te basket nut is tight.
Normally, there is a whirling noise until lever is pulled in. Which is normal.
ur describing a hub backing plate that's becoming loose allowing the cushion springs to get loose and rattle causing a jingling sound. need to pull hub and repair if necessary.
Custom Powder Coater
1 - 7 of 7 Posts
