1 - 4 of 4 Posts
I recently got a 15' ZX10 ABS and am trying to replace the clutch lever with a CRG lever. I go the clutch cable out but am having a hard time getting the stock lever off. Can someone point me in the right direction please. (First time DIY) Thank yoU!
Take the pivot bolt out, turn the adjuster all the way in until the slot all lines up with the perch. Then turn the lever 90 degrees and slide the cable out the bottom of the lever.
Don't forget to reuse the brass bushing from the stock lever or the lever will be too loose
take the pivot bolt out, turn the adjuster all the way in until the slot all lines up with the perch. Then turn the lever 90 degrees and slide the cable out the bottom of the lever.
+1
don't forget to reuse the brass bushing from the stock lever or the lever will be too loose
++1
1 - 4 of 4 Posts
