Tech question. Bike stalled on me the other day when I was rolling up to a stop sign with the clutch pulled in. Now when I try starting the bike in first with the clutch pulled in the bike moves forward. Like the clutch isn’t disengaging. I have proper 3mm clutch lever free play. Took the cover off last night, pulled plates out and measured stack height. Height was within service limit. Springs are all in spec. When I had the clutch plates out I put it in first and the bike rolled forward no problem, as expected. But when I put it all back together following the plate orientation per the service manual, I’m still having the same issue. I’m obviously missing something. If anyone has any input I would really all it!
