1 - 13 of 13 Posts
Anyone ever had this....just pulled my cover replacing clutch fibers and steels but never noticed this and see no shavings....but at the same time I don't see how this could happen.
grooves/marks
my 04 had same groove in cover, didnt appear to be from interference. a added safety margin when hub springs loosen and basket wobbles a little maybe? marks on outer hub appear to be clamp marks from holding fixture while machining blank hub. believe both are normal from the factory.
I had this issue when i put my billet basket in. It was 05mm bigger than the original. I Put the stock back and it was ok. It also made a weird sound when not engaged. My groove was way bigger than this.
Just check if everything is ok. Gen1 clutches make weird noises when cold :dontknow:
Discussion Starter #11
Sorry BUD but it has been Confirmed this is NORMAL by Cycle Concepts that has seen a Hub or 2 and a few other members......There is NO issue. :dontknow::wink:
bloo
Discussion Starter #13
I edited it before.I know...getting old :badteeth: :thumbsup:
ok....your edit didn't work :lol:....yeah old but good info for members never the less. :eek:ccasion1
bloo
1 - 13 of 13 Posts
