Clutch in but no start
1682 Views 14 Replies 5 Participants Last post by  Twist-IT
In the manual it says... Stand up/ In gear/ Clutch in/ Start
Mine will only start in nutrul as I found out after a stall in first. Just wonder if this is normal or if I have to investigate. I guess it didnt like the cold that much, lol.
Thanks in advance.
1 - 15 of 15 Posts
Probably a bad clutch switch. I had that happen on my 2014 and I sprayed some contact cleaner into the switch and it started working properly again.
  • Like
Reactions: 1
Cool, thanks man! I'll investigate.
Oh, and are those aftermarket levers? Have you checked to see if the clutch lever is actually depressing the clutch switch, and if so is it depressing it far enough?
Yes they are CRG levers and it does click when pulled and released.
If you have a multimeter you could set it to ohms and verify it's working when you pull the lever.
  • Like
Reactions: 1
I'll do that tomorrow when I get a chance, thanks for the help.
What tdh says. I've had two go bad. Easy to check if they are good or not though.
It's the aftermarket levers. You have the adjustment too close to the bar. The lever is hitting the clip-on before the clutch switch is released. The adjustable aftermarket clutch levers don't really offer you much adjustment because of this. That and the clutch is likely dragging somewhat now too.
There's a reason the stock lever is not adjustable. Set your clutch lever adjustment to the maximum setting (farthest from the clip-on) and try it again.
If that doesn't do it, then the clutch switch and sidestand switch should be checked.
I was assuming once he starts it in neutral and then puts it in gear it stays running when the stand is up. If that's the case it wouldn't be the sidestand switch and would most probably be the clutch switch. However, if it dies when he puts it in gear after starting with the sidestand up, then yes, it would be the sidestand switch. But, he wasn't fully clear on that.
  • Like
Reactions: 1
Yeah, good point. You're right. The sidestand switch wouldn't really have much to do with it in this case.
  • Like
Reactions: 1
It was filthy inside the switch and it just needed a good cleaning. Thanks all.
Does that gen have a kickstand sensor ?
Yes, it does.
After I cleaned the switch and it tested good it still wouldn't start so I took your advise, maxed out the leaver and viola, started. Thanks bud.
1 - 15 of 15 Posts
