1 - 4 of 4 Posts
Guys,
I can remove the damn clutch hub nut, is so tight!
I tryed to heat and no sucess, any tips???
Regards
SPiRiTY
I think impact wrench usually works good, if you dont have one try puting a bar on ratchet hold pressure on it while hitting the bar with hammer, hillbilly impact wrench!
What are you using to hold the hub with? You should be able to put a small breaker bar on it no problem. But you have to securely hold the hub. Should not need heat, and I don't recommend that anyway. If the breaker bar doesn't work, get an impact wrench and do it right. Rent one from an auto parts store if you don't have one.
1 - 4 of 4 Posts
