Was at the track yesterday and 3/4ths the time I shift from first to second at high rpm I am slipping back to neutral. I have two ideas but was hoping you guys could better inform me.
1st- tranny problem second is slipping out
2nd- positive neutral finder is catching cause maybe I am not shifting quite hard enough. It only slips back in high rpm's then I shift up again to second and its fine.
Next is on the front straight I felt like I was not getting as much power as normal. When I went back and watched the video the times before I was always hitting around 150 and this time I was lucky to get to 140 but was usually around 120-130. Could that be my clutch slightly slipping in the higher rpms? Any help I would greatly appreciate it.
Here is a video of me getting my friend on video but I still slip back into neutral. You can start watching at 1:50 seconds and it happens pretty soon.
