1 - 7 of 7 Posts
i seen a post a couple of month back but i can not seam to find it
anyways when i load the front end of my 06 10 (for instance if doing a burn out)i hear a click and sometimes 2 i don't see anything moving but there oviousley is i was wondering if anyone else has had this and found it or if the guy that had this problem ever found and fixed it
thanks in advance
jason
Tighten the neck bearings. That should solve the problem but if not it maybe the head bearings going bad.
checked and tightened the head bearings and it is still there i think i'm gonna tear the fairing's off and check for crack in frame
I have a clicking noise around my front end too. I mostly hear it when i back off the throttle a hair and when I pull in the clutch. I guess it does it when there is a slight load on the front. Any way I let the shop have it for a week and they couldnt figure out what it was and that it didnt seem to be messing anything up, and told me just ride it. I said ok but if anything happens it on them.
I've got a similar problem with mine at the moment. I called the bike shop and they said they've had a few that require the stem adjustment at the 6000km mark. The damper tends to mask the effect, I could tell it straight up on my old '04 when it was getting a bit loose.
Anyhoo, make sure your stem bearings are correctly torqued then go from there. Remember, for the home mechs ... you have to tighten the two nuts *under* the top triple, not the big nut sitting on top. That's there just to hold the top triple on.
:+1: I have seen this at first hand much to my horror, a mechanic getting a big mother of an air gun stick a socket on the top nut and pull the trigger on the gun and watch it rat a tat away for likes ages.... needless to say I bollocked him big time.
1 - 7 of 7 Posts
