1 - 5 of 5 Posts
MIA Ex-Mod
What for? Because the Kawasaki can't have one because the actuator is built into the clutch cover.
Tread
Of course you are faster
Sorry, can't be done on an operating ZX-10R (or most rice bikes)
It can be done on the Suzuki TLR/S, Busa, the SV1000R, and some of the older Gixxers... oh and I have done one Cajiva Raptor as well.
the reason (as stated above) is that the clutch basket actuator is part of the cover on the Kawi, if you punch a hole in it, you loose the ability to operate the clutch... My guess is that the show bike won't run on the street
Suzuki uses a push rod through the case from the left side of the bike (it has it's own seal problems so not a end all be all design either)... this means that the clutch basket cover (on the TL's) and the clutch cover on the SV,Busa, and Gixxer is just a cover, no support or mechanical equipment in it.
sorry, I make them, but only for the TL's, my lathe won't hold the monster Busa or Gixxer cover.
an SV a friend of mine did with one of my kits. The window is milky because the engine is not warm. once warm it's totally clear.
1 - 5 of 5 Posts
