1 - 5 of 5 Posts
Hi
If i want to plug the clean air system is it ok to just plug the hose marked A in the attached photo ? I have done this but got second thoughts if this will do or if i have to plug any other hoses ?
// Hobbe
all i did was follow that hose marked A in the pic to the TB's and pluged it with a marbel. works just same as block off plates just the plates cleans it up a bit underneath the airbox.
Yes. That works. Or remove the valve and run a hose between them. (and plug the airbox hole)
You just want to prevent air from entering the system.
1 - 5 of 5 Posts
