I posted this response in the recall thread, but figured it may be worth its own thread as well.
So, before and after the recall I was having 5th gear issues with my (race) bike (street bike has been fine). Bike didn't want to shift into 5th, especially higher RPMs under a load, and then cutting out at certain RPM ranges while rolling on the gas in 5th gear. Hardly use 6th so wasn't really able to test that very well.
Everyone kept telling me how it wasn't the transmission, had to be electronic. Changed mapping, tried different maps, finally installing the Kit ECU and harness. EXACT same problems. I finally got pissed off and decided to pull the transmission myself because Kawi kept arguing that it wasn't the transmission.
Well, that transmission is tore the f up! I'm fairly pissed seeing as though these issues were present before the recall, which means they didn't even LOOK at the rest of the transmission, just slapped in their recall kit and called it a day.
Here I've been riding around these problems for the better part of a year, everyone telling me it wasn't the transmission.
Symptoms were not typical "bad transmission" issues, as it was rolling on the gas in mid-range RPMs, mostly mid corner. Bike would cut out, then jerk back in, sometimes a couple times. Which was mildly terrifying at those speeds I might add. Mapping changes helped with, but didn't eliminate, the shifting issues, but by this last round I was getting semi-regular false neutrals. Disconnecting the quick shifter helped with the shifting, which seemed fine using the clutch old-school style, which also threw off my "chase" of the real cause.
It's not super common, but I am not the only one I've heard of having these issues. If you have been having them, I'd recommend taking a look at what is going on inside!
Considering Kawasaki sells transmission shims in their "race kit" catalog and says they are there to "help with longevity and positive engagement" there is obviously an issue with the transmission in a track/race environment, which these bikes OUGHT to be built for.
