1 - 4 of 4 Posts
Hey fellas!
Ive got a 1st gen with 45,000 k's on the clock and think its about time i changed the fork oil . my fork seals still look fine and dont need replacing yet.
Do i require any special tools just to change the fork oil?? how much do i put in?? and what should be the level from the top??
Also has anyone got a link to the electronic version of the manual??
Any help will be appreciated. Cheers!!
Premium Member
It is a royal pain. You need a spring compressor, air tools to remove the bolt at the bottom, and a holder for the inner part of the cartridge when you are re-assembling it.
HA it's not too bad if you are just changing the oil. Remove the forks from the triple clamps, and then do the following:
unscrew the preload cap
turn fork upside down and pour out old oil
pump the leg several times with the fork upside down to get as much out as you can.
If it's super dirty, refill with gas or cleaning solvent, pump the leg, and dump it out
put in a little fresh oil, pump the leg, and dump it out. It should come out clean.
now, use a cc cup to measure oil and fill the fork with fresh oil equal to the amount specified in the manual (pay attention to model year).
Make sure you have pumped all the air bubbles out, and verify the oil height is even between the two forks.
Screw the preload cap back on, and reinstall the forks in the bike
DONE
1 - 4 of 4 Posts
