1 - 10 of 10 Posts
The topic was talked about between a few friends, all we came up with was in 05 they added a slipper clutch. Were the any other changes between 04 and 05?
The '04 also had a slipper clutch, in fact the only changes I'm aware off is the sticker colour, from gold-ish to red (I think)...but I have been wrong before :wink:
Just a few differences. Both had a slipper clutch the 05 they went with a stiffer spring rate in suspension and I believe it was a different shift star in trans. to help smooth out the shifting.
Heres the changes from 04 to 05. Robbed it from a old thread
Clutch cable and some related brackets for routing
Rear timing chain guide
Turn signals with mounting hardware
Rod Bolts
Front Brake Pads
Forks
Shock
Shift Star, Detent Arm, and Spring
Muffler
Header
Mid-Pipe
Fan Assy
Rear Brake Master Cylinder
Taillight
Transmission Input & Output Shafts
3rd Gear
Rod Bolts
Front Brake Pads
Forks
Shock
Muffler
Header
Mid-Pipe
Fan Assy
Taillight
3rd Gear
wow you are a god amoung men Thank you everyone
one for added note
the 04 generators blew up ruining the motor
they fixed this issue
and the only thing i could brag about after i bought a 05 zx10r that was bone stock for the same price by buddy got a 04 10r with full acra pipe power commander and every other mod imaginal for these damn bikes
just my 2 cents
Rod Bolts
Front Brake Pads
Forks
Shock
Muffler
Header
Mid-Pipe
Fan Assy
Taillight
3rd Gear
Did all of these changes amount to an increase in hp for the 05's over the 04's? Or were they made for some other reasons?
:dontknow:
1 - 10 of 10 Posts
