1 - 11 of 11 Posts
I changed the oil and filter in my '05 and put in 3 quarts. When I stand the bike up, the oil level is all the way to the top of the sight glass. What gives? I thought this thing took 3 quarts. That seems to have put me a tad on the high side...
Did you start it and let it run for about 3 min?? if not do that and then let it settle before checking the level again.
BTW it takes 3.2qts W/filter and 2.9qts without a filter.
per the manual 2.7 litres (2.9 us quarts) no filter change
3.0 litres (3.2 us quarts) with filter. US quart is less than a litre, imperial quart is more. 1 imperial quart = 1.2 litres. Quantities were right for my 04. When you drained the oil did you get the motor hot prior as this makes a difference. With the oil cold you don't get as much out? Did you use imperial quarts? Cheers
lol already answered just as i hit the post button
I just woke up. lol Party last night
Discussion Starter #8
I did run the engine before I drained it, but probably not as much as I should have. It has been ridden since the change, so I know the oil has been circulated well. I just double checked the oil, and it's about halfway between the high mark and the top of the glass. Is that enough to matter?
Nope that was how mine came back from the dealer after a service
Better a little bit more than less, so long as its not too much
I always start my bike and let it run for a few moments, then drain it for a good 10 minutes while i get all my tools and rags, and other crap ready. I then bump the starter a time or two. Just enough to roll the motor over and cause the oil pump to circulate. This causes a good gulp or two of the old oil to drain.
Then just pour 2.5 quarts in and start the bike for a brief second to fill your new filter. Shut the bike off, wait a bit and pour oil in to the proper level. Run the bike again and double check the level, while the bike is level.
Go ride :)
1 - 11 of 11 Posts
