1 - 20 of 22 Posts
Piece of cake to install, they look good and are quality pieces. I highly recommend them. Hopefully I'll never need them at the track but you just never know.
Hey those look great!! I hope that dog does'nt lift a leg on your front tire like my neighbors' dog did.:angryfire
LOL, oh hell no, Hailey knows better than to try that.
I am thinking of getting a set. My main concern is the bike tipping over in a parking lot or something. They look good.
Starbucks Connoisseur
Those look very similare to Lockhart,does anyone know which brand out of the two stick out farther?
and much was yours for the set?
Yankee Racer
+1 for champs sliders, been down plenty of times with them and they do a great job protecting the bike, tank...etc... Great product and Champ91(Pete) is a great guy
+1 to that too. The sliders held up amicably after a lowside and the good thing was the bracket wasn't even damaged or bent. I only had to purchase a new slider (minus the bracket) from Champ91 to get the bike back up!
Discussion Starter #11
It is a quality product for sure. Hoping never to have the need but I'm sure the time will come now that I'm a track addict.
Yankee Racer
it will happen eventually unfortunately.....just hope it is a small get off with minor damage:thumbsup:
I have the Shogun no cut but I can't see them being anywhere near as good as Champs. I'd go with Champs if I had to do it over again.
:+1:
I went with Lockhart Phillips because of the price and thought all no-cut sliders were the same. Well surprise! surprise! There not. Lockharts mounts their bracket one side with a bolt and the other side just with a spacer pushed up against a nut end of an engine mount. CRAPPY!! Will it hold? :dontknow: Will I stay with Lockhart? Hell no!!
Will those get in the way of your legs while you are rotating around the tank?
I'm 6'3..... I need to find some sliders that won't get in the way of my knees...
Do a search - there is a thread that talks about this. Some guy was 6 4 and they worked fine for him.
zx10ragentblack is kinda tall i think 6'3 or 4 been a while since I've seen JJ. I say kinda as Im 6'6" and he's shorter than me lol Says he has no problems with them at the track.
MY oo ITCH said:
:+1:
Sounds similar to my mounting.
2004-5 Installation pics at www.champindustries.net/zx10.html
2006 Installation Pics at www.champindustries.net/06zx10.html
But as posted by several people I know mine hold.
I'm sorry Champ. Well your half right. On the clutch side (06 model) you use a stud with a nut end for the (D) side. Lockhart just has a stud that pushes up against the nut. It looks like the brake side is the same as Lockhart.
Why didn't you use the (nut-stud) on the brake side??
Once again I'm sorry didn't mean to dis your product. I was actually going to call you for a replacement for that stud side bolt.
Pretty simple. Stock its a pass through bolt with a nut on one side. If I were to mount my posts on both sides it would require a new bolt and another Stainless Steel post. Both would add to the cost of the sliders. Thats not a bad idea but its not needed. When the entire assembly is mounted and locked in on the front, they are rock solid and perform well in a crash.
1 - 20 of 22 Posts
