At that price? Probably a used one.Im sure its been covered but i hate using the search function. Gen 3 is in need of chain replacement. Stick with the 525. Whats the best gold chain in the $100-$125 range?
Front sprocket is fairly new. Rear sprocket will be new with the chain.At that price? Probably a used one.
If your chain is that worn out, so are your sprockets. Going to need to up your budget substantially to get a quality setup. EK, DID, RK, etc.
Well that's good. The you need to see what Mike at Rider's Discount has. The EK MVXZ might be close to that budget.Front sprocket is fairly new. Rear sprocket will be new with the chain.
Exactly the chain i was about to post. 525 mvxz is 9300 tensile strength. Thats what id be mainly concerned with. Only chains higher a couple other models and then the 3d chains. Pretty sure thats the way to go for the money. $103 shipped on amazon from EKWell that's good. The you need to see what Mike at Rider's Discount has. The EK MVXZ might be close to that budget.
