1 - 10 of 10 Posts
Stock is 112 links. Most likely that's the number you will need. They come 120 links so you'll have to cut it. The easiest way is to measure it on the bike with your particular setup. However, with that combo, you should have enough adjustment to run the standard length.
Discussion Starter · #6 ·
Ya I'm just gonna pop the sprockets on and run the chain and then zip tie it up and ya. Thanks guys as always
I can confirm for you. Stock chain (112 links) fits -1/+2 sprockets. (although after re-reading, I have the feeling you were asking just to make sure the other guy got an answer, not because you needed to know)
Can anyone tell me what length Chain I need to get for a Evil swing arm. For Gen 4...I wanna set it at 6...Thanks...
You need to be asking Evil that question. Plus, nobody is going to know how long your chain needs to be even on SWB without knowing about your sprockets.
1 - 10 of 10 Posts
