1 - 20 of 23 Posts
What is the best chain cleaner out on the market? And the next best. Then the cheapest that gets the job done.... [smilie=2:
Clean your chain????? :eek:
You mean I could've got more than 24,000 miles from my 9R's 530 chain if I'd cleaned it? Damn. :x
yes that is correct. I use WD-40 sprayed on a rag to wipe it down
I was kidding. :) The WD-4 then chain wax process is how I did get 24,000 miles from that OEM 530 chain.
simple Green or Kero, then dry it and WD-40 it. Don't use 'chain lube' on it or all you'll do it get it dirty faster. O-ring chains don't need 'lube' like non o-ring (dirtbike) chains do.
I was always under the impression that the lube is for the sprockets and to prevent rust.
the WD-40 will disperse H2O and prevent rust.
Gentleman we have metal on metal here which necessitates a lubricant no matter if they are O/X-ring chains or not.
uhhh i think i am going to have to agree with the above statment, lube good :)
DMPPerformance said:
100% correct, the rollers do not have seals. The X-ring seals are on the pins between the plates. If you will notice, the rollers are independant of the X-rings. I spray WD-40 or similar onto the chain with a shop towel below the chain to catch the mess. Wipe the chain down to get rid of the excess WD-40. And then I lube with Chain Wax on the inside of the rollers. I continue to spin the wheel for a while to let the propelent in the Chain Wax evaporate so the Chain Wax will not sling off. I got almost 27,000 miles out of a stock R1 chain like that and I probably could have nursed it to 35,000 miles. The sprockets showed no visable wear. And the chain had very little stretch. I changed because the rear wheel didn't spin as freely as it had before and I figured the reason was that the chain wasn't as free as it had been. When I put on the new chain, it spun freely again.
Thats crazy I have always taken pretty good care of my chains and I have never gotten more than 15k out of one
It is marketed under the brand name of Chain Wax. It is in a black and gold can. They also have a black and silver can. I don't know what the difference is. I have always stuck with the black and gold Chain Wax. About 7 bucks at the local K shop.
It's probably Maxima Chain Wax. Don't know about the silver can but the gold can stuff doesn't fling off too bad. It's alot better than PJ1, what a mess.
Clean it with W-D or an actual chain cleaner and Lube it with your choice of chain lube after every ride just as you would wash the bike after every ride and it won't leave you out in the cold one day! And for those who are going to go off on this statement, If you use it as a commuter, Do this every 300 miles, This doesn't take long to do and it pays for itself many times over, Like Zeta said, The rollers are not sealed and do get dry and or dirty!
I read a lot of people use WD 40 to clean their chain, doesn't WD 40 contain components that (slowly) dissolve the rubber O-rings?
1 - 20 of 23 Posts
