GoFaster said:
To get an old bearing out, you have to bang the inner race out from the other side. A big heavy-duty flat screwdriver can work. A round chunk of steel a little smaller than the ID of the bearing (so that it will fit thru the one on the other side) will work if it has good sharp edges. It can be a minor hassle ...
Bearings that have been removed in this manner should never be re-used. The hammering can damage the balls.
To install it, you must push it in using the outer race only - NEVER push on the inner race. I usually find a big socket that has an outside diameter a little smaller than the OD of the bearing, and then tap the bearing in evenly using a hammer. Tap on alternate sides of the bearing to get it to go in straight. When the tapping changes from a dull sound to a sharp ringing, the bearing is seated ...
If i may expound on GoFaster's detailed instructions just a bit.
My tools of choice for removal:
1 12" long center punch with a flat tip
1 2lb hammer
When you begin this you'll notice the inner spacer makes contact with both inner races so it needs to be cocked to one side before you can gain access to the inner race/s so insert the 12" punch down through until it gets close to the opposite end and rest the tip against the inner wall of the spacer and tap on it sideways until the spacer moves to one side enough that the inner race is exposed enough to get the tip of the punch flat against it and begin your caveman technique of bearing removal. :badteeth:
My tools of choice for installation:
1 hydraulic press @ my local friendly dealerhsip (BVH) along with a socket matching or just slightly smaller than the outer race and hammer.
I use the press to handle the majority of the install but the final few millimeters should be done by hand ( hammer & socket ) as you'll have a much better feel as the bearing seats into the wheel and bottoms out.
And another lill tidbit is the rating scale for bearings that i'm sure GoFaster is knowlegable of is called 'ABEC' and it's basically a measurement of the clearance between the ball bearing & inner race and just so everyone knows these particular bearings i've used and given you part #'s for are rated ABEC1 which are at the bottom of the scale, as it goes to ABEC3, ABEC5, ABEC7, ABEC9 etc. Some may say 'well WTF is that' and my only reply would be were talkin fractions of thousandths within the ABEC rating scale so relax and breath you'll be fine in the morning.
