Hi,
I'm busy installing the transmission bearings on my bike and ran in to a bit of a problem.
On the tail side of the shaft the clutch runs on there is a housing with a bearing. The bearing I removed had a dust seal on the inside but my new bearing does not have this dust seal.
Do I need the seal? This bikes are expensive to fix, need to make sure of this.
