1 - 9 of 9 Posts
I just got a akrapovic and mid pipe from ebay the carbon slip on and mid pipe for 530 shipped it was slightly used. the only problem i ran into was there was a o2 sensor hole in the mid pipe which i dont need, so im just gonna plug it up with bolt non welding. I think thats the best way to do, any else have any other suggestions.
yes plug it dont weld it!!!
this way if you decide you want an auto tuner or motty later the o2 bung is already there
thanks. i just wanted to double check. well installation has ended for tonight broke one of the exhaust clamps the one from midpipe to header. the bolt was seized in it. i guess ill have to take a trip to the auto part store tomorrow see if they have the same size one in stock
i do have to admit this board has been very helpful since i got my bike i appreciate all the info and tips i am getting. those wires that went from the stock exhaust to under the seat were fun lol, but you guys made it easy on here just searched and found a thread how to remove without throwing a code. thanx again and ill post some pics when i finish the install
i just got done with the mid pipe and slip on install and what a pain it has been. one of the exhuast clamps broke and the other one sucks. there is a decent amount of exhuast leak from mid pipe to slip on i guess i will have to use some copper rtv or does anyone else have any suggestions
Licensed Dist of HaterAde
I'm still amazed you paid $530 for a USED half system/slip on........that's NUTZ!!!!!
Hopefully you used the stock gasket when adding your slip on but you can use some silcone to help seal it up
Push the clamp as far to the back of the bike as you can and seal it up with a layer of copper gasket:thumbsup:
1 - 9 of 9 Posts
