1 - 2 of 2 Posts
got the Motion pro carb tool and tried to sync my gen 1, I got 3 very close but I had to turn the screw out so far on one that I am afraid it will vibrate loose and fall out, these are the only screws that I can see to adjust and all were in all the way, am I doing something wrong ? I damn sure don't want to loose a screw during a race or I will be screwed for sure
I had a motion pro and it wasn't very accurate. I ended up buying a Morgan Carbtune Pro and it was more accurate and easier to use. Like the Motion Pro, the Carbtune has easy to see marks to get an even level of pressure. The only difference is the Carbtune has the vacuum pressure readings on it which allows you to have the right amount of vacuum pressure.
Sent from Motorcycle.com App
1 - 2 of 2 Posts
