1 - 8 of 8 Posts
I can't get the stock damper bracket off (the bracket that mounts under the steering....there are two bolts, I don't want to strip the nuts....any advice the are super tight!
MIA Ex-Mod
I would loosen and remove the top triple and set it on a bench so you can get to it better.
Tread
Huh...I got those two loose without a problem...it's the one that attaches to the end of the rod that I stripped out.:headshake
Granted I had the upper cowling off when I took those two bolts off but I think something else needed to come off to get that off so I said fuck it...I'll just have to carefully drill that bolt out when I get a new one from Ron Ayers...or say fuck it and leave the factory fluid in the damper...
I know it can be a PITA but if you have the right allen bit I used a socket to do it and had no problem. You'll get her, just go slow and be careful!
I replaced mine with stainless allen bolts from Mclendon's hadrware. Worth every cent..replace them if you get them off ;)
Sounds much more painless...those security bits suck...hence why it's stripped out...
I..
I did use a socket with the allen still very tight!
Do..
you have to take the triple...thing off, I tried again and oh well I'm leaving it on there
Discussion Starter #8
Okay....I got the 2 bolts off and the bracket is still mounted to something? I suck.....anyone have advice?
1 - 8 of 8 Posts
