I don't have a F'ing clue, so stop being a tease and tell us lol.I tried to follow these instructions, and it's my own stupidity that threw the codes, but I must not be doing this right.
So here's what happened. Did my base line STOCK Dyno run this evening. Any guesses what she pulled bone stock?
I had the ABS dongle installed and both wheels disabled, just as I should have. But at the end of the run, I shut the ignition off, and my cousin asked me what the temp was, and I turned the ignition back on with the back wheel still spinning down...and we all know the ABS reactivates if you turn the ignition off...:angryfire:
So now I have the all blinking dash.
Went home and looked these instructions up, and maybe I'm not understanding them.
Turn the ignition switch on and start the engine, did that
1. Run the engine more than 10 minutes (at idle???) didn't do that.
2. keep the idling speed more than 30 seconds (did that)
3. Run more than 5 minutes at speed of 25Mph or more, did that
4. Turn the ignition off, did that
Repeat 3 times, did that.
Still same flashing dash.
What did I miss? Was it the Run more than 10 minutes? Because I idle, this think would easily overheat. I let idle for 30 seconds or more and then did the 5 minute jaunts.
I know my dealer can reset this, but I do not live near my dealer. I know Woolich can reset this, but it may be next week before I install it.
Any help?
