This is my first clutch change on this bike. The first time I changed one was on a '09 gsxr 750 and it went flawlessly. And yea, i adjust it at the clutch cover first, you know, pull the cable forward till its tight and tighten the adjusting nuts, then try to fine tune it up at the clutch lever. My problem is that i've got no more room on the adjustment at either end now. The only thing I could come up with is that maybe since the new friction plates aren't worn like the old ones that they're gonna be a little thicker but still, aside from slipping under hard acceleration my old clutch worked right and still had room for adjustment. I've taken the cover off and checked to make sure I have everything lined up right, double checked myself, everything. I had to step back for a minute cuz this is getting frustrating. Any help is good help at this point. Thanks guys.
