1 - 3 of 3 Posts
Licensed Dist of HaterAde
as long as the spacing is the same where they mount to the forks which is 108mm on the 04-05's AND they use the same diameter of rotors......? 300mm for the 1st gen's.
You need the discs as well, the '09 ZX10R has 310mm discs and the caliper is built to suit. I run this setup on my Gen 2.
1 - 3 of 3 Posts
