has anyone ever experienced this, i took the bike out i stopped at the light stopped at stop sign then all of a sudden i notice the bike started slowing when rolling in neutral, well the front calipers locked shut, the lever felt as if i was pulling on it when i wasnt, luckily i was 3 blocks from my house i got my 8 mm wrench and bled off some brake fluid to release the pressure, i rode home not using front brake, ok well in the garage i pulled on the brake lever about 3 or 4 times and sure enough cant spin front wheel because the calipers are closed again without releasing. also the fluid in reservoir is right in the middle of those lines so i didnt over fill it.
also i installed new nissin caliper
