took them out today, very good mod for free i would recomend thanks for all the input
ccasion1:thumbsup:
Someone just posted something like this a few days ago:wink: but yeah, I did the same this past weekend and woke it right uptook them out today, very good mod for free i would recomend thanks for all the inputccasion1:thumbsup:
an 07 i assume?took them out today, very good mod for free i would recomend thanks for all the inputccasion1:thumbsup:
just the plates, and its an o4Did you just take the plates out or did you remove the rod and all?
starts fine runs great no lights, everything is the same except a little more powerful on the open road!!:thumbsup:How is it when the bike starts cold? and is the FI light on?
i would try it, its very easy and worst case you put them back in?thinking about doing it on my 06.. I'm not looking for the problems tho.. or maybe i am wrong?? i live in a high elevated cold climate could cause problems
I didnt want to at first intell I could tune it on a dyno, so a couple weeks back I had a chance to take them out before my tune and gained 3hp for real, bike woke up, truth it felt like I dropped from a stock 17 tooth sprocket up front to a 16 tooth, a lot more power in the lower rpm's around 2000-4500
:deadhorse:yes, if you have done this mod you know that its basically the same thing as a tre but for free, its a must, on my last dyno run/tune I had removed my secondary's and gained 3hp and gain .6 something in torque. So no loses, only gains. Hope you like the mod!!
or when your boosting at 7psi and you realize what your doing is a felony then you slam on the break so you dont give every rider out there a bad rapWait, our bikes has butterflies? Only butterflies I know of are the ones I get when I walk into my living room and see all my 10's staring at me!
i suppose but overall why waste the money on the tre when you could put it toward a custom tune and youd never even know it was there. trust me, when i purchased my pc3 used the seller threw in the tre for free, i installed it and was happy i didnt pay a dime and if it wasnt a such a pain to install (its harness in deep between the motor and frame) i prob wouldve removed it ans sold it to you suckers but i didnt have the heart to rip ya off:wink:It's true everything u said..i have a gipro and i had several runs on the dyno with the tre on and off and there was no hp gain..but better throttle respons.specialy in setting #2...
Now if i remove the secondaries and have the gipro on can i still have hp gain and better throttle respons?????
