1 - 6 of 6 Posts
Good morning,
Anyone running a busa shock ???? If so what settings are you using? Compression?? Rebound?? I'm @ 64" with a P1, just want to see what those of you are using a busa shock,settings what works????
Fyi gen 3, geared 15/43, no, race intake, bmc race, no flies, full system, u4.4...thanks in advance.
im runnin a gen2 busa shock on my swb zx10 which is a nice upgrade over the stock shock and the compression/rebound is set medium and im 200 pounds suited if that helps ya.
Thanks....I'm goin with 2 clicks, from full soft on both..
1 - 6 of 6 Posts
