A plug broke in my +3mm build I'm not sure why after 1500 miles if it was a million in one fault or heat damage (engine never registered above normal temps) but the puzzle is the head gasket (cometic 0.018 X 79me) has broken or burned through between the 4 (damaged piston) & 3 cylinders thankfully no head or valve damage but I'd like to know why it happened so hopefully I can prevent it happening again.
