1 - 20 of 20 Posts
I have the Gen 5 and changing the bulb is one of my projects this winter. I do not want to upgrade to an HID set up because my friend told me that once a dust got onto the headlight lens the dust will be very noticeable.
So do you guys know a bright headlight bulb out there? White color if possible
Thanks!
Thanks!
few options: Philips Extreme Vision or Osram Nightbreakers/Nightracers as stock replacement bulbs are good. Much better throw than stock
You can also consider putting tiny auxillary LEDs on the bike which you can switch on whenever needed. Few from Denalli are tiny AF and are hardly visible when hidden around the fairing. You get loads of cheapass Chinese ones too. A 20W on each side should give you the help you looking for
Thanks!
I don't understand your or your friend's train of thought. What does this even mean?
"I do not want to upgrade to an HID set up because my friend told me that once a dust got onto the headlight lens the dust will be very noticeable. "
1. What dust?
2. How is it getting in?
3. If you have dust where you park your bike it will be there anyway.
4. Are you saying that HID causes dust?
I'm not selling you HID, just trying to understand this nonsense.
Premium Member
'16 ZX-10R KRT
1. What dust?
I'm with this guy ^^^^. You don't want to upgrade to HID because of....dust? :screwy: If you're worried about dust, don't ever open up the bulb sockets and just leave them the way they are.
I have ran HID's in my zx6r for 7 years with no "dust" issues and have had hid's in my zx10r for a year now. I'll be picking up my zx14r up in a few weeks and the first mod ill be doing is hid's. I really don't understand what your friend is talking about.
Yes, those are the ones i have. Like i said before, they are not the bluest and coolest looking bulbs. But from my research they should last the longest, increase night time vision, and make the color of the lights a bit more white compared to oem. If you want more blue, i have read good things about phillips diamond vision. I wouldn't get the sylvania zxe, i read those will burn out quickly. Also PIAA Xtreme White Plus seem to be a good bulb as well. But for the money and performance, it is hard to beat the Silverstar Ultra.
2021 ZX10R (Street) 2021 ZX10R (Race)
I think his friends problem is that with the HID kit you have to drill out the back of the OEM light cover. If you do not ask for a Grommet (rubber boot/cover) then dust can work its way in the light through the air vents.
At one point allot of kits came with rubber boots in case you needed them, now days they are options you have to ask the seller to send.
ive had HID kits on every gen of zx10R since 2006...no issues at all.
but this is what the grommet looks like and I bet his friends kit did not come with it.
  • Like
Reactions: JepoyDaNinja
This grommet is not even necessary if you're willing to do the work and your hands are attached to the correct place.
1. Carefully take off the connectors from hid bulb.
2. Cut off grommet and throw away
3. Snake bulb wires through same location your headlight OEM wires go through. (Bit of pain but duable)
4. Snake power wire through same home as bulbs to connect from (OEM power to bulb) to new ballast.
5. Use double sided tape to hold ballasts in lower side fairing
5. Connect all remaining wires.
BTW, even if you drill and do all the work off the bike, properly, there's no dust. It's the most ridiculous reason I've ever heard in my life.
Even blinker fluid is more real than this dust he speaks of.
Done
2017 zx10r and 2019 ninja 400 Abs
I just installed led headlights in my 2017 zx10r.
Cougar Motor H7 LED Bulb
I read this article before ordering. I was not sure what was meant or have a seen a follow up other then the comments that followed shortly after about the dust comment.
I think I understand what he was trying to say as I can see it with my own two eyes. I clean my bike alot. The outside of my headlight lens are perfectly clean. Starting the bike up they look clean with the oem headlights. Aiming a flash light at them they look clean. After I installed the led lights. They are brighter for sure and more white. But in the inside of the lens you can see any particle of dust that has collected over time. As in I even re washed the lens after turning the lights on just to see. Mine are not for bad. But with the lights on yes you see dust on the inside of the lens. With it so bright it just stands out is all.
Still happy with the purchase. No issues. The bulb fit into place and was able to use dust caps with no modification. There probably isn't a mm of space from the cover to the end of the led but it screwed on and fit with the light harness plugging right into the bulb. Now it's to see what I think at night. If I don't follow up it means I'm very happy with the results. If I think it's off or a I'm not happy with the results I'll follow that up. Have a great day.
1 - 20 of 20 Posts
