1 - 9 of 9 Posts
anyone run these tires on the street yet? Im torn between what to get this time around. i loved the stock bt-016 and i put corsa III's on when i bought replacement tires. i am stuck with what to get, another set of corsa III's, going back to the bt-016 as they are a little cheaper in the cost department, or trying out the new BT-003rs's as they are the same cost as the 016's. any input on the 003rs would be appreciated.
thanks
anthony
I currently have BT-003's. They are not as sticky as the PCIII's. The BT-016's are next up and they are actually stickier than the BT-003's, comparable to the PCIII's yet will last a lot longer.
Basically the BT-016's are the way to go for the canyon carver. PCIII's just dont last long enough.
Discussion Starter · #4 ·
thats odd, from everything i have read on sites that sell the tires the 003rs are supposed to be a tire more in line with racing then the 016. i loved the 016 that came on the 08 but i had to try the dc3's. i got better life out of the dc3's then i got out of the 016's but that doesn't mean to much to me as i was at the drag strip more on the 016's then the corsa 3's. keep the opinions coming as i welcome them.
i am having a hell of a time finding a good quality green 525 chain though, anyone know of a good one? i really do not want to convert to a 520 if i don't have to but i do want the green chain so i might have to bite the bullet on that one.
thanks
anthony
anthony
Can't believe everything you read:) I haven't used them yet BUT two of the tire reviews that I have read have said that the 016 actually has more grip BUT isn't as easy to contol when sliding.
I heard the 003rs fronts are off the hook = primo the rear 003rs are not as good as the front 003rs !
the 016 rear is killer rear tire with great feedback street and track great wear
the front 016 different story work well but i could never get much more them about 800-1000 miles before the side tread was toast
Im going to order a front 003rs & a rear 016 that may be the ticket and that set can be had for about 269.00 delivered to your front door so there may be a savings with that combo as well ?
I have tried many combos of tires & the dunlop GPA 209 soft compound on the front is the best so far and I love them vs 016 front
however the rear dunlop GPA 209 is like the front 016 I cant get any wear and IMO the dunlop GPA 209 on the rear dont work as well as the 016 on the rear ?
go figure LOL... good luck man
with tires = most every rider likes just a little different feel and some guys are faster then others so you need to give a few combos a try until you find something that you like !
1 - 9 of 9 Posts
